861 Draft Control
Anonymous-0
I rebuilt and adjusted the lift cover on an 861 about 5 years ago. I plow a plot about 170x75 each year. Last year I noticed when I raised the lift lever all the way up the 3-point would not come up all the way when in draft postion like it did when I originally adjusted it. Does it need re-adjusted, or what exactly is the problem? I don't know why it would be out of adjustment no more that I plow with it.
Nathan
i have a 901 and a 3000, diesels that gave me the same problem.
cut off the motor and let the lift all the way down. when you cranck back the tractor give it plenty of throttle, and raise your lift and your draft effort, worked for me until i re-done my lift
