8630 loping at low idle
Lukesdad
Bought a 8630 last fall and getting ready for hay season this spring/summer. For some reason the tractor will lope (if I let it lope it gets to the point where it will rock the tractor a little - pretty aggressive). Doesn"t miss, sputter, etc, just lopes at low idle. If I speed up it a bit always smoothes right out.
Is this indicator of anything, or should I not worry about it?
THanks
Minimec's tend to do that at low idle when they're cold... particularly when the pump gets some wear.
Make sure the cam box vent is not plugged up tho.
Rod
I've owned mine for about 4 years now. It lopes at idle when cold but runs fine when warm. I have had no engine problems with this tractor since I have owned it. I'm not worried about mine.
