I just picked up an 1970 870 gasser recently with powershift. The other day I went to take it down the road to fill it up with gas. Starting out in 4th gear and the tractor had no power trying to go down the road. Even when shifting up, it wasn't changing speeds, in fact it actually started slowing down. It wouldn't even throttle up. Almost like the brakes are stuck and the tractor can't go. Except the brakes didn't smell nor were hot.
What I'm assuming to be the powershift hydro body in the rear of the tractor smelled hot, was smoking or steaming, and hydraulic fluid was burping out of the filler neck in the back (with the cap on). It was burping out enough that there was a trail of fluid down the road and in my driveway.
I had made it about 1/2 mile before turning around and heading back home. It does fine in 1-3rd gear.
Just wondering how bad the situation is for this tractor and what issue is indicated by these symptoms. Not sure if I should send it down the road or try to rejuvenate it. Tractor is in pretty decent condition.
This post was edited by Lizer on 07/19/2021 at 07:46 pm.
