The pto shaft on my 871 had about 3/8" fore and aft movement. Thinking it was the split
ring I pulled the shaft. Split ring is OK. Appears the outer race is a loose fit. I
have a donor rear end from another tractor and it's pto output race is also a loose fit.
(The donor shaft external splines are wallowed out from a hard life.) The machined
surface for the inner sleeved bearing is scored from the hydraulic pump shrapnel from an
earlier failure.
My questions are 1) Is the output bearing race a drive fit or a loose fit? I don't recall
our 851 having this movement. 2) How important is the sleeve bearing for the internal
support? The oil seal appears to be holding OK.
earlier failure.
