Bennett French
I have removed the PTO shaft and bearing retainer from my 4 speed Ford 2000. To remove the output shaft from the retainer the disassembly instructions say to remove the snap ring from the front of the retainer (assembly diagram shows this to be the larger of two snap rings) and remove the shaft and bearing from the retainer. I have removed the larger snap ring from the retainer, but the output shaft and bearing will not come out. The assembly does move forward about the width of the snap ring groove in the retainer, but then stops hard. When I look from the forward end of the retainer, at the bearing, I see nothing preventing the assembly from coming out. When I look into the rear of the retainer where the output shaft comes through, I see what looks like the rubber of the oil seal surrounding the shaft, but I also see what looks like the part that the assembly diagram calls the sleeve coming through the oil seal and out to the base of the splines. What appears to be preventing the removal of the assembly is the sleeve coming in contact with the rubber of the seal as I try to pull the shaft and bearing forward. It is definitely when forward motion stops. I have tried hitting it from the aft end with a small rubber mallet with no success. I am reluctant to hit it any harder without asking for advice.
Thanks.
Thanks.
