The starter on my 88 occasionally will not engage. It will grind. Not everytime, but occasionally. The starter is probably less than 10 years old and has not had allot of use.
Sometimes, I will press the starter button and it will grind, then if you just tap the starter button, it will engage and be fine. Not sure the brand, it does not have a Delco name one it.
I am using the 88 consistently this fall and the grinding is annoying.
Thoughts? Shall I just replace it and forget it?
Good source to get one? Are there American made starters?
This one is 12 volt.
