8n 12 volt battery
NOT as far as I know, unless from a specialty outfit making original-looking 12-Volt batteries for vehicle restorations.
WHY is this important to you... for APPEARANCE,or FUNCTION?
You can buy a 12 volt batt. with the positive on the right or left side of the battery. 12 volt conections are normally in the corners as opposed to 6 volts in the center of the narrow end.
Both...It looks as though the original cables that I purchased will only fit if the terminals are diagonally located on the battery.
(quoted from post at 20:55:21 01/06/08) Both...It looks as though the original cables that I purchased will only fit if the terminals are diagonally located on the battery.
Which one is too short?
The Ground?
The cables come in different lengths.
