8N,9N,2N front wheels
Anonymous-0
I am fixing up an early 8N. It has original front 400x19 steel rims. I will be keeping this, and while I don"t want to alter it much, I am thinking about getting some old 6 lug truck rims and put wider tires on it. What type/model rims should I be looking for? Or is there an after mkt new available? I thought I saw some in a catalog but can"t find it now. Thanks.
Are the ones you have the small bolt pattern or the big bolt pattern. If its the small one most newer 6 lug type tractor wheels will bolt right on and can be found at any tractor dealer or farm and home store. And they even come in 15 or 16 inch and probably a few other sizes
Hobby farm
On you ford 8n the 6 bolt wheel will be correct most 6 bolt found will work but watch the off set.If by chance it is 5 bolt then it is a 9n or 2n there pattern is by it self.let me know if I can be any help.We salvage fords .thanks doug@agexternal_link
Actually.. it's a 3x19 rim.. and is a 4x19 tire...
TSC sells front rims that will hold 5, 5.5, and 6x16 tires... Might even hold 6.5 tires. ( that is if you do in fact have the small pattern hub, and it has not been changed tot he wide 5-bolt lug of an 9n/2n.. etc.
Soundguy
