grandpa Love
This wire appears to be pulled out of this connection. Would this keep alternator from charging? If amp is bad will that keep it from charging?
That wire being disconnected will cause it to overcharge." Well, SOMETIMES. Earlier units will do as you say, but later units do just the opposite and output nothing when 'sense' wire is disconnected.(quoted from post at 15:29:24 04/17/19) That wire being disconnected will cause it to overcharge. If it were run very long that way, it may have damaged the alternator, overheated it.
Try reconnecting it.
Then turn the ignition on, should get some voltage on the #1 terminal. If no voltage there, check that circuit. It should go back to the ignition side of the ignition switch, but pass through an indicator light or diode first.
Also be sure the big wire is hot from the battery or amp meter.
10SI Wiring
But it's ok to check a generator
that way?
