8N cold starting problem
Anonymous-0
I just got this old tractor last spring. I have done a good bit of maintenance on it. It will start beautifully in warm weather but when it gets below fifty degrees it will not start. It has new plugs, wires, battery, coil points/cond., 12v system, rebuilt carb. and nothing will make it start below fifty degrees. It cranks fast and it fires but then the starter slips off and I can crank it again and it fires once and the starter slips off and on and on and on until the batter goes dead. I can pull it with my truck and it will start right up. Any suggestions anyone may have will be welcome. I have read all the other cold weather tips on this site but my problem seems to be different.
When you ask a question here, it’s usually a good idea to tell us:
1. The model of your tractor (2N, 9N, 8N, NAA, etc).
2. If it is 6v or 12v.
3. If it’s an N, if the distributor is on the front or side of the engine.
4. If it has any major parts that are not OEM, such as electronic ignition, a side coil on a front distributor, etc.
Troubleshooting is different depending on the model of the tractor, voltage, ignition system & distributor placement.
And, even if you told us that last week, remember that you’re dealing w/ a bunch of guys w/ CRS.
We are missing one critical piece of information: front or side distributor?
You have four related problems:
You have the old style bendix.
It needs a tune-up (all those new parts won't help much if you set the points gap wrong or didn't set the timing)
You fouled the plugs trying to get it started.
You drained the battery resulting in low ignition voltage.
Get the newer style bendix & tune up on the tractor.
Replace the plugs. If you flooded it, they're fouled & it will be it next to impossible to start. You don't need to toss them; heat the tips for a few seconds w/ a propane torch to burn off the invisible spark-robbing deposits from today's additive filled gasoline........or wash them in lacquer thinner.
Charge the battery.
It works like this......the bendix engages the ring gear on the flywheel & turns the engine over. When the engine speed exceeds the design speed of the bendix (because the engine is running) it disengages. (and I can never remember what RPM that is) All the new style bendix does is allow a higher engine speed before it disengages.
What is happening in your engine is that 1 or 2 plugs fire, the engine momentarily exceeds the bendix disengage RPM.....and it disengages before you have all 4 firing.
If you want to tune it up, just ask; plenty of folks can walk you through that (but see tip # 39 first). We need to know if it's a front or side distributor.
And, if you want to pull the starter & replace the bendix, just ask about that as well.
50 Tips
This is a front mounted dist. on and 8N tractor.
I have started it by pulling so why do I need to replace the plugs?
Is it a front mounnt or a side mount distributor?
Is th e timing correct and the advance not sticking?
You did"t mention using the choke.
Are your valves adjusted to the correct lash?
I believe you may be right about the bendix. It does slip off way too easily. And by the time it coasts down and stops (maybe twenty seconds)it never really has a chance to start up.
aloing with a bendix, I think I'd do a compression test on her too to get an idea of engine condition.
soundguy
Yes, I have thought of that but have not gotten to it. Is there and good shop service manuals that you might recommend? I have never done any major large engine overhaul but am not afraid to learn. I have rebuilt some small lawn mower engines.
Thamks for the suggestions.
I thought you said you were cranking it & the bendix disengaged & you kept it up until you drained the battery...........
Regardless, if you got it going the plugs are now fine.
Tip # 39 will tell you what manuals to get.
You said you replaced the points; what was the gap & did you set the timing? If it's out of time, it will be hard to start.
50 Tips
You need a new starter bendix drive. Get the newer type and it will stay engaged until the engine is up and running.
To use the newer type bendix you should grind out the hole in the block where the starter goes. Grind it to the outside at least one inch more than the opening is now. This will allow the newer type bendix to be installed lots easier.
What ever you do don't test start the starter while it off the tractor after the new bendix has been installed. If you do you will never get the bendix installed into the tractor engine until it has been retracted. Don't do it!
Zane
Try this and see if this works:leave key off,turn over[throttle about 2clicks on]a couple revs,popping choke out &in quickly. Turn on key and try it No choke unless it fires,then give it just enough choke to keep it running.---lha
I'd get the I&T fo-4 service manual as well as the owners manual and the master parts catalog.
you may not even need an overhaul.. wet/dry comp numbers plus oil pressure will tell you if you do or don't.
soundguy
Trying to make oneself clear seems to be a problem when trying to describe a problem.
I do appreciate all the many tips and suggestions that I have received on this site. I know everyone here knows more than I do about the old 8N front distributor tractor.
What I mean to say is, When it is above fifty degrees it seems to start up just fine. But when the weather gets cold it will not start. It will fire and the gear slips off. When I let the starter coast to a stop and try it again it will fire once and then the starter slips off. I do not continue to hold the starter engaged, what is the point of that?
I believe ZANE is correct about what the problem must be. I have also thought the same thing but didn't know how to keep the starter engaged longer. It slips off at the very first sign of a spark plug firing. I have had the starter out a few times and the bendix looks fine but it does slip off way to easily.
I will try to replace the bendix and see if that helps the problem. I have tried to change the timing and the carb adjustment but that does nothing to help.
One other point if I may. I replaced the six volt coil with a 12v coil and did not keep the resistor in the circuit. The coil burned out in less than two hours. I replaced the coil again and put the resistor back in and have had no probmem after months of use. Why do I need the resistor with the 12v. coil? This makes no sense to me. Why buy a 12v. coil if the resistor is still needed? Even the people at Yesterday's Tractor, from whom I purchased the new coil and resistor, could not explain this to me. They only said, well, you have to have the resistor and we don't know why either.
Thanks again for everyone's help. I really do appreaciate how good strangers are to come to the rescue of someone they don't know when dealing with the old tractors.
Wayne
The old style bendix will work just fine as it was designed to work if you have everything else in perfect order. It not a matter of looking at it to see if it's bad. It's not bad. It just disengages at a lower RPM.
Tell us how you set the timing. It's not all that easy on a front mount. (e.g., use the wrong side of the tang & you get the wrong results)
BTW, I'm not discounting a compression problem; it would be to your advantage to check it out.
Regarding the coil..........technology & materials being what they were in the 30's, that square coil would melt if it ran on much more than 4 amps for any length of time. (see tip # 38 for an example). In order to get a hot spark at the same time the starter was drawing max current from the battery, a ballast resistor was added in the ignition circuit. What that did was add about .3 ohms of resistance in the circuit, added to the 1.5 ohms of the coil. That got you 3.5 amps or so at start up. As the voltage increased when the engine was running to about 7.5 volts, the resistor heated up, adding more resistance in the circuit. 1.0 ohms hot, plus 1.5 ohms of the coil got you down to 3 amps or so to keep from melting the coil. The same rule (actually, Ohm's Law) applies to a 12v circuit. I= E/R. Current equals voltage divided by resistance.
It used to be before the "Land of Almost Right" started making coils that you could count on a 12v frontmount coil as having 3 ohms of internal resistance & the 6v coils as having 1.5 ohms or less. Thus, thanks to Ohm's Law, you could calculate what additional resistance you needed in the circuit to limit coil current to 3.5 amps. So, you will need to measure the internal resistance of any new coil, 6v or 12v, & see what it is. A digital multi-meter has two probes & a switch. Set the switch on resistance. Put one probe on the top of the coil & the other on the pigtail at the bottom. It will give you a reading in ohms. Lets just say it reads 3.0 ohms. Your OEM ballast resistor (which you must use) is about 1 ohm hot. A coil a 3.0 ohms, plus the ballast resistor at 1 ohm (hot) gives you 4.0 ohms resistance in the circuit. Your 12 volt alternator puts out 14.5 volts. You need to determine current (amps). 14.5 v divided by 4.0 ohms gets you 3.6 amps; close, and probably safe. But, and this is the problem......what if the coil is only 2 ohms? Do the math. 14.5 volts divided by 3.0 ohms gets you 4.8 amps! Not good! And, if the coil is less than 2 ohms (and some are) it will fry quickly. So, to get it to 3.5 amps, you need another resistor in the circuit. Either that, or keep spare $30 coil around.
50 Tips
I would jump ignition switch and check battery connections.My switch works when it wants to,but I've got 2 for backup(3 tractors that need'em).I'm going to change it soon.
I did measure the ohm's of the coild and it was 3 ohms for the 12v. coil. But a 12v. coil is a 12v. coil supposedly made to run in a 12V. system. Whd do I need the resistor in the circuit? If I need the resister for a 6V. coil (which I can understand when I am using it in a 12V. circuit) WHY do I need a resistor in a circuit that is using a 12V. coil??? This makes absolutely no sense at all! I have a 12V. coil in my truck and a 12V. system and there is NO resistor in that circuit. Why not just continue to use a 6V. coil and the resistor?
Ohm's Law.
As I said, not all 12v coils have the same internal resistance. Did you have any resistor at all in front of the 3 ohm coil? Do the math. 14.5 volts, 3 ohms, you get 4.8 amps.
You need to keep the current below 4 amps.
Use the 6v coil, the OEM ballast resistor & what ever additional resistors are required to get the coil current to 3.5 amps.
50 Tips
Marketing and oem applications.. they get in the way of facts.
Lotsa times you see a box that says in big letters... 12v.. then in little flyspec print it will say.. 'with serial resistance'
menaing that coil is for a 12v application with n extra resistor.
i see it all the time. Not saying that's what yours is.. just saying that is why there is some confusion of 6v and 12v and real 12v coils.. etc.
soundguy
