Please help me figure this out. Have search the internet but haven't found anything similar.
My '52 8n just started a knocking noise from what sounds like the top end. Here's what I've done since it started:
Oil change with 40 wt. and new filter.
Compression test. 100 on all four.
Oil pressure 25-35 while bushhogging
depending on height of grass
Yesterday was knocking at idle, under load and everthing in between. This morning, not nearly as bad at idle.
While experimenting, I started removing one plug wire at a time while running. Knocking ceases when wire removed from first plug from back. Resumes when wire is reconnected.
I don't see any evidence of manifold leak.
Any ideas? DELL, HOBO, anyone????
