TraktorTom289
This is my third message as I chase my problem to
ground. I discovered my tractor wouldnt turn over
because the ring gear spins on the flywheel
I split the 8n and removed the flywheel to find Ring
gear to flywheel welds that had broken. I
removed that ring gear and cleaned up the flywheel.
I noticed that the ring gear sits on a diameter of the
flywheel SMALLER than the diameter it has to pass
over when expanded by heat. Is this normal for
the flywheel to have a pocket that the ring gear
shrinks in to? I have pictures but havent figured
out how to post. I could email them if you think
they would help clarify my situation. Thank you
