Greybeard PA
My sheet metal is all finished and in the paint shop as I write this. I'd surely like to be able to get the hood and grille to fit like they should.
Every 8N grille I have ever worked with was smacked somewhere on the lower paner, below the vertical bars. When this happens, these things tend to lose their integrity in the distance from the pivot pin on the dog leg to the top corner of the grille frame. This results in the grille being either too long to fit properly against the hood or too short for the springloaded pins to fit into the holes in the hood.
My question is this: does anyone know this dimenmsion, or failing that, does anyone have an un-smacked part they could measure and report this dimension. This information certainly wsould be a good thing for 8N owners to have when refinishing or replacing a grille panel - unless you can afford one of those nice new ones Dennis Carpenter sells.
