8N hydraulics
LLavery
Question
I was using my 3 point with an auger last weekend this weekend I went to use the auger and the 3 point will not lift.
Where should I start it is full of fluid
See tip # 16. Make sure you have a heavy load on it, like the auger. Post back w/ what you see in there.
Move the touch control lever and make sure the control rod moves and is attached to the pump.
75 Tips
(quoted from post at 14:56:21 08/06/23) PTO engaged? Needs to be or no hyd.
What JMOR said, makes using an auger with an 8N a bit of a pain as the auger has to be spinning to raise the hydraulics unless you take the PTO connection loose each time.
thank you for the reply
I am such a dummy I have owned this tractor for years I brain faded and didn't think about turning on the PTO. No excuse have been working for John Deere for years with live ptos and just forgot
Thank you
Larry
