8N Industrial Engine
rbuckel.......Ford DIDN'T......its been "hot-rodded" and rebuilt with NO sleeves and '40 Merc pistons. More cu-in equals more power. Simple, eh? .......Dell
(quoted from post at 22:33:49 12/09/09) rbuckel.......Ford DIDN'T......its been "hot-rodded" and rebuilt with NO sleeves and '40 Merc pistons. More cu-in equals more power. Simple, eh? .......Dell
What is the HP gain dell?
8n with star after eng number has 040 sleeves.
With diamond after number, it has 080 sleeves.
The star engine can be run with no sleeves and .083 or .100 over pistons. With power dome pistons and a GP cam, it will put out 34-36 HP
@2500 rpm., and 50 hp at 4000 rpm. on 87 octane.
Add a 2bbl carb and a Sherman head,,, who knows?
My dad rebuilt our 8n with NO sleeves and '40 Merc pistons in 1958. It worked great for about a year then lost power and started burning oil again. The mechanics of the day in ower area didn't think the cast used in the block was high enough quality to run a piston in. Was the ford industrial made of better stuff ??
Cheers
Eldon
Untitled URL Link
Industrial engines were produced sleeveless with a standard bore,,, the same standard bore a sleeve engine would have with the sleeves installed
BTW they also did not have harden valve seats
WARNING :shock: all I know I read on the Internet,,, do it enuff and you can become a guru also,,, not responsible for damages,,, I read it and just pass it along,,, proceed with caution
We tore on down at a Massy dealer I worked for, and someone had taken the sleeves out and put oversize rings on the stock pistons.(didn t work very long)
(quoted from post at 03:25:04 12/10/09) Probably been asked a few times already, but why did Ford make the 8N Industrial engine with no sleeves?
The others are confusing a tractor engine with you question,,, I spec the industrial engine was not as acceptable to ware issues as the tractor engine,,, no sleeves and other upgrades to ware parts would have made the industrial engine cheaper to produce....
Whats the serial number stamped on yer block,,, that would answer some questions....
I believe you are correct. I over-hauled and used std rings. For now she is running great and is used every summer to rake hay.
