JV Texas
my 8n suddenly has water in the oil. Is there anything other than a busted block, busted head gasket or head that might cause this? I"ve taken the motor down to removing the head and the gasket looks good. Just want some input before I preceed with the overhaul. thanks
You have hit the only 3 things I know of that would cause that problem. I have seen head gaskets that looked ok but they still leaked. If your going to do a complete over haul/engine rebuild I would have the head and block magnafluxed just to be on the safe side
Hobby farm
I'd put the head and hoses back on, refill with water/antifreeze solution, and then pull the pan. Put light pressure to the radiator and look to see where the water comes from.
