I need advice from you Ford engine experts out there! I have an old 8N with a front-mount distributor that I’ve had for a year or so. It was rough when I got it so I didn’t expect too much and the price was pretty good. It has always started easily, but has little power and seems to be getting worse. After it starts I have to continually keep some degree of choke. I now keep a clothes pin handy to clip onto the choke rod to keep the choke partially closed. And if it starts pulling, I have to continually keep fluttering the choke or it stalls.
So, any ideas? Where should I start? Carb? Bad valves? Compression? Tire pressure? ….. just kidding! I only use this tractor occasionally for light work but I’d sure like to have it running well. If you can offer suggestions as to where to start looking for the problem – or maybe multiple problems – I’d appreciate it. Thanks, John
