8n pto problem
Anonymous-0
pto will not engage push on lever i can hear it grinding like it wants to go in but wont this happened when i was brush hogging heard a bang sheared pin on brush hog hasnt worked since would greatly appreciate advice
My uneducated expectation is that a tractor with a live PTO has a friction clutch that might slip a bit, delivering less torque when the drive is overloaded. Bush hoggen with my 8N I have broken a lot of the (5/16", I think) shear pins of different grades and not done other damage. The 8N, not having the live PTO clutch, has the output shaft hard-wired to the rear drive wheels and the forward momentum of the entire unit and torque of the engine are transferred directly to the PTO output shaft.
