8N steering gear box
sicky
can't find the recommended 90w mineral oil for my 8N steering gear box. Can I use 80-90w or 85-90w standard gear oil as a substitute? Anybody know how much it holds?
Thanks for your help.
The thicker the better... 85/140 is as thin as I would put in it.. I'd even go with a nlgi 00# grease.. like JD cornhead grease.
The same 90w oil you use for your rear end would be suitable for your steering gear.
It doesn't hold much.. 2 tubes of grease will fill the box and tube up to the steering wheel.
soundguy
Sicky........we recommend 2-tubes of sticky (byte my tongue) John Deere cornhead grease. $5 (cheap) The biggest problem with 90wt mineral oil is it leaks and doesn't lube the upper ballnut bearing and that WEARS and causes loose and sloppy steering. You doubt? Jack yer frontend up so you can "swing" yer steering wheel and watch yer steering HUB for uppsie'n'downsies. BAD BEARING from lack of lubrication. Cornhead grease don't leak and keeps everything well lubed.......Dell
Holy Hannah Guys - If I read the post about the gearbox that appears just below, I kinda screwed up because I put SAE 30 wt oil in that little plug hole for the gear box on my 8n. Is that why it leaks oil like crazy out the steering coupling below the gear box. What do you do, just squeeze that thick grease into the little hole alongside the gearbox? I feel kind of stupid and should have done a little research before I gave it a good oiling.
Rich
Rich......ya sur'n'ell don't squeeze sticky oil in middle of minn winter (grin)
Remove yer eazy to gitt-to gear cover plate under yer battery tray. And letter all dump out down the side of the tractor into a buckett. Squirt'ter some with solvent of choice. I use paint thinner mineral spirits but you can use kerosene or diesel. Replace cover plate.
While yer cleanin-up, have yer 2-tubes of sticky cornhead oil in HOT SUNNY WINDOW, and summagunn it will squirt into yer fill'em-up hole withoutta buncha effort. Simple, eh? .......Dell
