Irish_Jake
Evening all - you may remember me from previous topics here https://forums.yesterdaystractors.com/viewtopic.php?p=9036363&highlight=#9036363 .
I've gotten back to the tractor again, fixed the valve lash clearance, and have begun to assemble the tractor again. However, after putting on the manifold I noticed something strange that fits with earlier observations - I'm getting suction at the exhaust port on the manifold, and pressure at the intake port on the carb. It's consistent in the sense that I only get suction at exhaust and pressure at the intake (the amount of suction/pressure varies as the engine turns over).
I'm turning the engine over with the starter, so unless it's possible for the starter to turn backward either because I replaced the solenoid or wired it wrong, I'm leaning toward the camshaft being the issue. From the tests I was advised to run in previous threads my camshaft timing -looks- correct, my #4 valves are fully closed when the #1 cylinder is at TDC. However, one thread I found here noted that a camshaft 180* out of phase could cause the issue I'm seeing, and although it wasn't totally clear it seems like in that case rather than 90* out of phase I might not see evidence of a problem using that test. I did replace the camshaft gear during my rebuild after shredding it by ignoring one of the 75 tips and running a bolt into it's teeth.
Thoughts and advice? I'm going to double check my wiring but most of my googling along those lines makes me think the starter can't/won't turn backward (and a lot of the threads I found just shifted into old timers waxing poetic). I'm leaning toward the camshaft gear as the culprit, just want input before I lift the tank and tear down the front end again.
