8N wont start
RDAllison
My 8N won’t start.
The spark plug firing order is correct. There are good sparks from all the plugs. The compression in all the cylinders is above 110psi and below 120 psi.
All the fuel filters are clean and fuel flows freely to the carb drain. The main power needle is 1 ½ turns from closed position. The idle mixture needle is 1 turn from closed position. The carb is a brand new 8N9510C I bought from this site.
I took the air filter off until I can get it started.
The engine will only sputter after cranking on full throttle and closing, but will not disengage the starter drive.
Is this a carb problem or something with the ignition/timing?
Thanks,
RDAllison
Front or side mount distributor?? 6 or 12 volts??? both can make a difference as to us being able to help you. Is your spark and nice blue/white and will it jump a 1/4 inch gap. If it is not then you have a spark problem
It is a 1949 front mount 12V.
It has a good spark (blue).
How exactly do test for 1/4" gap? Do you set the plug gapping to 1/4"???
Allison.......you write......."The main power needle is 1 ½ turns from closed position. The idle mixture needle is 1 turn from closed position"......I find best is down-point main power needle 2-turns. and side-pointing idlemix 1/2-turn (or less after starting and warming up) Idle speed is an incredibly SLOOOooow 400rpms. I adjust the idlemix for fastest idle, NOT smoothest idle. Remember, the side-pointing idlemix is BASSACKWARDS; out for lean, IN for ENRICH.
Define good spark. Will yer sparkies jump a full 3/16" gap? My eazy starting 6v 52-8N will jump over 3/8" gap.
When was the last time you replace yer points and timed yer engine??? ......Dell, yer self-appointed sparkie-meister
2 ways to check for a 1/4-3/16 spark gap. You can widen the gap on a plug to 3/16s or hold a plug wire 1/4 inch from the block. You can also with the air tube off hold your hand over the carb inlet and make sure it has a good suction there and it might even try to start doing so but you can also gas foul the plugs doing that. I would maybe try a new set of plugs also auto lite 437s are what most people say to use in them N series tractors
Allison.......make a calibrated sparkie tester outta enny old sparkie. Bend the side electrode out for full 3/16" gap. Visegrip the metal shell to convinent bracket. Plug enny sparkie wire to top of tester. With tranny in neutral (engine will start with 3-sparkies) ignition switch ON, crank yer starter motor while watching the calibrated tester and evaluate yer sparkies. Do they jump the gap with blue-snott authority? or are they a wimpy yellowish-orangish poor excuse? or no sparkies at all??? .......Dell, yer self-appointed sparkie-meister
I have few questions how do I tell the RPM? I don’t have a proofmeter.
The center post in the spark plug is only 1/8 inch from the inside wall of the plug. So how do you test for 1/4-inch gap?
I did bend the side arm out so it was straight then held the end of that arm to the engine block and it sparked across the center post to the sidewall with a blue/white (maybe light yellow) spark.
I replaced the distributor cap, coil and put in an ignition kit in April of 2007. I timed the engine after that.
I found another symptom, after cranking the engine gas starts dripping from the carb.
There is good suction from the carb air intake and I just replaced the plugs with the autolite 437.
Allison........you write....."I found another symptom, after cranking the engine gas starts dripping from the carb. There is good suction from the carb air intake and I just replaced the plugs with the autolite 437"........ennytime you have gas drippin' from yer carb drain and it still won't start, ya done FLOODED yer sparkies with invisible contaminates. REPLACE yer FLOODED sparkies with clean dry AutoLite 437's gapped 0.025". Don't throw yer flooded sparkies away; clean'n'dry them one-atta-time in HOT running engine and save'um fer next time you have startin' issues. And there will be a next time.
Dunno about yer 1/8" gap problem. AutoLite 437's have extended tips, (take a closer look) and the closest metal for a gap is the bent-out electrode. Yer test is probably ok. ......Dell
