My 8N won’t start.
The spark plug firing order is correct. There are good sparks from all the plugs. The compression in all the cylinders is above 110psi and below 120 psi.
All the fuel filters are clean and fuel flows freely to the carb drain. The main power needle is 1 ½ turns from closed position. The idle mixture needle is 1 turn from closed position. The carb is a brand new 8N9510C I bought from this site.
I took the air filter off until I can get it started.
The engine will only sputter after cranking on full throttle and closing, but will not disengage the starter drive.
Is this a carb problem or something with the ignition/timing?
Thanks,
RDAllison
Thanks,
RDAllison
