9 Bolt to 8 Bolt adapters
Brian-Ont
I have 13.6-28 9 Bolt rims on my 1010JD. The tires are shot and I have a set of 16.9-24 8 Bolt tires & rims off of a 585 Case. The diameter is very close to each other. Does any one make an adapter from 9 bolt to 8 Bolt?
Thanks for any help or input.
Brian
PS I use this tractor on a hobby farm and for snow plowing, so it doesn"t see a hard life.
post them and trade for the ones you need you should be able to get some tires in exchange for the tires and rim off the case.Used of corse but the 28" rim is common even if the 13.6 is not just don't go far from the 13.6 as it will be harder to get to seal.
Hi bigdiesel
I sent you an email, if you don"t receive it, let me know on this site and i"ll try again.
Thanks for the response.
Brian
