966 vs 1066
how can you tell the difference between the two ? have a new puller in the club and we believe its a 966 that if memory serve's me they didn;t come with turbo's , but it has 1066 sheet metal,turbo and its in the 8500 lb class , serial numbers were ground off the motor which looks like a truck motor , so i am trying to figure out how to tell wjat we have here-been told by another member he was bounced out of two different clubs , they claim it had a 966 tag on the block but i checked that but noe it reads 1066 but we all know hoe easy it is to make a tag up , please get back to me , thanks
if it has 3pt, the arms are different 10 has a horseshoe joint at the top. 9 will have flat front across the fuel tank ,a 10 will have an angle on the right side for the turbo to clear. Not to many differences. I don't see a reason to be picking on him, just my opinion. Right side of late truck motors will have the navistar diamond instead of the IH symbol.
he must be winning!nobody ever really cares unless you beat someone.thats reason to pick on him.just go ahead and kick him out of club.
Whats the big deal, do you want him to buy a 1086 then bore the block to put the 466 sleeves,or JD sleeves then stroke the 466 crank. and have up to a 650 with the correct numbers.
youo keep talking about the serial number of the motor, what about the serial number of the tractor, I think they are around the lower part of the bellhousing somewhere. There really isnt much difference, if its a 966 with a turboed engine, its no different than a 1066.
He must be doing good or no one would care what it is.In a club full of rule benders, with not so stock tractors I think its BS that your on here trying to find ways to stop so one from pulling.Read the serial number data book.Tractor serial numbers are all the matters,cause we all know how easy it is to put a motor that doesn't belong it the tractor.As for truck motors you can make any 414 a 466 with different liners and pistons.
YES,IWAS TOLD IT WAS A 966 TO BEGIN WITH,THEY CAME WITHOUT TURBO'S,THEY ADDED 1066 METAL AND TURBO AND A BUNCH OF MOTOR WORK,NOT FAIR TO OTHER PULLERS AND MIGHT OPEN A CAN OF WORMS BECASUE EVERYONE ELSE WILL FOLLOW
it pulls in open class in ma,ri,nh and pulls stock with us thats not right its gotta go. theres the same problum with the super stock as well they have to use the stock block thats not happening
