973 Crawler Loader
Hi guys I have a 1992 973 86G030xx crawler loader; I want to know if hydraulic fluid 68 can be used for the trans, anyone and thanks in advance
No you cannot, For lack of a better term, it has a "slippery agent" not good for friction disc"s same with motor oil. you can use motor oil in the hyd, the cat owners manual tells you what you can and cannot use. allot of contractors will use motor oil to replace hyd, oil because it is cheaper and one less tank to have on the lube truck,
Yes but it must be 10 not any heavier or it will need a long warm up to start moving. It is a hydraulic system not a regular transmission .
Later Bob
