98 JEEP LAREDO
(quoted from post at 10:33:42 04/27/10) Thanx , but I doubt that >..it has worked fine all winter ,,, problem came about after warm weather and Ac has been used ...
Can you reach your hand up in there to see if it is cable, vacuum, or electric? Maybe something just came loose at one end or the other.
Dave
(reply to post at 14:33:03 04/27/10)
It sounds like you have a Blend Door Problem. If this is the problem, it can be a real pain in the BUTT. And can be very expensive. Google Heater treater or www.heatertreater.net you will find procedures on how to check the blend doors and accuator.
The blend doors blend hot and cold air that comes out of the vents
Good Luck
Try flushing the heater core. I have a 97 and mine worked fine right until it plugged up. They don't flow a lot of water but when they are plugged you get no heat.
