99 dodge cummins fuel pump
Anonymous-0
My buddy has a99 dodge 3500 with cummins 5.9L.Went to change fuel filter and whne we tried to bleed the filter we could not get any fuel to come up. The electric pump runs 2-3 second and quits. Tried it 20 times and still no fuel.Do we need a new pump or is something we are missing.He also saya that when he pulls a trailer with a load on it the rpms jump up and down.I have not drove the truck myself but it my sound like the trany is slipping.Any Thoughts
Ron
lift pump could be bad, it is not in the tank it is above the starter, under the fuel filter. Small hands are a plus to change it. Be careful with the wiring harness on the bottom of it. three mounting cap screws (bolts) and two fuel fittings, plug it back in, and you are fixed. They have come way down in price, I have put 2 on my 99 ctd, 180,000 miles. A warning light for pressure drop or fuel pressure guage is recommended.....as said if allowed to run very long with a weak or bad lift pump.....your bosch vp44 injector pump will die and co$t pretty good to resurrect.
The lift pump is for sure bad.When I changed one out a while back,I found the OE style for the cheapest price at Carquest.Incidentally,it was bad for so long,it ruined the injection pump.
Sounds like your injection pump is bad also.Pull codes from PCM.There are usually codes stored when they go South.
RVS, to primeup after filter is drained is to turn key on and hit starter, dont need to crank, just pickup the hold relay, runs, I think about 20 seconds or more n HTH
The original lift pumps were on the engine. That is the bad type to have. The replacements go in the fuel tank. If the engine is run long enough with a weak lift pump, the main pump takes a dump too. The concern is usually surging.
do tell.....didnt know about the replacement pumps in the tank. who in their right mind would pull the fuel tank and modify it for a pump when they could replace the pump on the block? AND as I said....a warning of some type is needed to know BEFORE a pump dies. If a lift pump in the tank dies, does it do less damage to the same injector pump than lift pump on the block does....I DOUBT IT. Read what was said before you post....I have found that to be a virtue.
The ones in the tank go bad just as often as the ones on the engine and they are a hell of alot harder to change to.
Brian, you are entirely correct. The electric pump mounted on the block is nothing but trouble. The replacement kit that eliminates the block mounted pump and wires in a pump in the tank is much more reliable. When the delivery pump goes bad, then the injection pump goes bad also. I've replaced a lot of them over the years. I do not recommend installing the low fuel pressure light that is available. The only accurate way to monitor the fuel pressure is to put a good guage.
I have replaced a lot of pumps on Cummins diesels, and I have only seen two bad in-tank delivery pumps. In fact I have an 02 sitting in the bay waiting for an injector pump right now. The reason for putting the pumps in the tank is because the pumps push much better than pull.
I will agree with you in that a pump works better pushing than pulling. But I have an 03 common rail cummins, if the pump on the back of the fuel filter goes bad will it ruin my high pressure pump? Plus its alot easier to replace the pump on the back of the fuel filter base than an in tank pump.
As far as I know, all the common rail systems have the in tank pump. By the way when the in tank pump fails on a common rail the truck will just quit running. So far, I haven't seen the high pressure pump go bad. However I have replaced LOTS of injectors on the common rail.
SCHMUCK 2
The truck DIDN'T run fine before filter change.You might want to read original post!
Picked up a new pump from NAPA first thing this morning.It is still the block mount,but a completly different pump,even says it is new and improved on the box.No major mods just a90 on the fuel inlet line,same bolt pattern,little bit different setup for outlet.Turn on the key with one line off to see if it ran longer.It ran and did not stop without pressure,had to disconnect pump wiring.Hookud up the line and tried it again,only ran 3-4 seconds and stopped.Opened up the bleeder on top of the filter and it was full already.Let out some air and the truck started fine,ran fine.Took it down the road and seemed to have more power empty.Will have get it loaded up to see if it helps with the surging. A Thanks for the confirmation on the pump replacement.I will let you know about the loade performance later. Thansk again
Ron
My uncle has been running cummins since they came in pickups and by far the best truck he has had is a common rail. I think the pump is in the tank but an aftermarket one bolts on behind the fuel filter. Alot easier to change. Do it every 100k and he is fine.
