jeffalex2
I got my new 9N home and have started working on it. Right side brakes work great, left-not at all. Might as well do both...the shop manual makes pulling the axles sound easy. What am I in for?
You are not missing anything as far as pulling the axles BUT removing the springs and re-installing the new shoes was beyond the amount of lead in my rear end....my rear end not the tractors rearend.I simply was not strong enough to wrestle the springs on and off. I took the axle assembly to a local auto repair shop and got them to install the shoes, then I re-assembled the axle assemblies to the tractor. Good luck. Let us know how you come out. Thanks
The brake springs are stout, but not too difficult if you have a brake spring tool. The brake video is helpful if you are new to this. I had to hammer the axles pretty good to get them out.
I didn't find the job terribly difficult, although some heavy lifting is involved.
First and foremost, be sure you have the rear end securely held up. There will be some sideways pulling, and you don't want it to fall!!
Removal is kinda easy. Un-bolt, and pull out.
The normal problem with 9N brakes is oil on the shoes and drum, from bad seals.
You will want to get the new kind of outer seals and install them (after cleaning everything). Doing so will change the whole deal to a much better way of sealing the oil into the diffy. They're not expensive, and eliminate having to press the old ones off with a special press. You simply leave the old ones in place and put the new ones at the other end of the assembly. Sounds complicated, but you will see it's easy.
I cleaned my drums and shoes with kerosene first, then laquer thinner, then brake cleaner, then lacquer thinner.
What you want to do, and I didn't know about and am sorry I didn't do, is run your belt sander over the shoes (lengthwise) after you have cleaned them. This scuffs them up and makes them grab, whereas they were slick and smooth before.
All in all, if the shoes still have lining on them, yo don't have to wrestle with the springs. All the cleaning and scuffing can be done with them in place.
While you're in there, you can fiddle with the adjustment thingy and see how it works, so you will know how to adjust your brakes after everything is buttoned up. What I found is up = tighter, down = looser (wrench handle).
Best of luck!
The brake system on the 9N is totally different from the 8N. Everything from how to take them apart to how they work. The manuals I have are heavy on 8N, but it's mostly intuitive.
you gotta be kiddin, just clean and install a sure seal? If you're doing this what are you doing for bearing lube? Without lube on yer bearings they are going to fail and eat up yer sure seal and oil up your brakes again. Do it right the first time. Completely disassemble remove collar and bearing, replace your outer seal and inspect bearing and race for pitts replace if needed, pack bearings with quality wheel grease not chassis grease, and then install new collar and then a sure seal.
I have had bad luck with sure seals. A new orig type seal is best, and the axel end play must be zero, or you are wasting your time. Do not get oily fingerprints on shoes.
Guess it just depends. My Dad installed Sure seals in his probably at least 40 yrs ago and they have never leaked yet, and he has used it heavy maintaining 20 acres and garden spots and deer plots etc.Installed them in mine 5-1/2 yrs ago and no problem. Mine gets no use so really can't judge by it.
It's not necessarily easy. Pulling the axles is not hard if you have a strong back. It's also not optional...you need good brakes. Put the rear end on (2) jack stands and dig into it and see what is up. I just did a complete brake liner replacement on a 2N and would be happy to help. Check out the pins where the lift arms on your 3 pt hang. If you have leaking you need to fix it while doing the brake job...you'll be half way there. Absolutely plan on using the more modern style seals. Also, go to Steiner website and look at the small rivet tool for brakes. Made my life a lot easier. Start a new thread for additional.
(quoted from post at 06:03:50 01/05/10) I have had bad luck with sure seals. A new orig type seal is best, and the axel end play must be zero, or you are wasting your time. Do not get oily fingerprints on shoes.
ron8,
There is a difference in outer seals for 2n brakes. I ordered some on line, part #9N-4251. When slid down in place on the axle just to see how they fit they really slopped around on it. I can't imagine how they could seal in oil or grease. I then bought a set at the local ford parts dealer and tried them and found they have a very firm feel around the shaft. They bear the part number D6NN4251A and are about half the thickness (~1/4 inch) of the set purchased on line. Turns out a local auto parts store sells this same thinner seal.
My inclination like your's is to go without sure seals. My 2n restoration project had sure seals and the right brake was saturated with oil. The left wasn't much better.
Depends,,, if you want to fix correctly one time and be done with it replace the outer seal also,,, it you are a gambler cover up the mess with a sure seal.. a sure seal is nuttiin more than a deflector that helps keep the axle oil out of the bearing,,, nuttin sure about it,,, if and they always are the outer seal is bad it will leak grease on your shoes.
I don't think any one could make a argument that the outer seal does not need to be replaced, it was put their for a reason.... As bad as this job is to do I want to do it one time, get this event over with. The reason these brakes get a bad rap is folks haft arse it,,, How could anyone take a gamble on a 70 year old axle bearing ? with out at least inspecting it and installing a new outer seal to keep the lube in and the dirt out,,, done right they are better than 8N brakes ever could be... 56 and up Ford went back to the 9/2N style axle set up,,, the 8N axle/hub was a real goof...
