Through the help of other users on the main board, I think I've determined that I need to replace the coil on my '42 9N. It shuts off after getting warmed up and doesn't spark until after sufficiently cooling off. Then it runs for a little while and shuts off again. So, if anyone can send me instructions on how to replace the coil (6V) I would be very appreciative. Looks like coils are readily available online for around $30 or so. Thanks in advance for any help or advice.
"....doesn't spark until after sufficiently cooling off. "
How do you know that? Did you "test" the coil as soon as the tractor stopped by open an old plug to a 1/4" gap & looking for spark? There are ways to check for spark that work & ways that don't. For example, some folks think that checking for spark means pulling a plug wire off & looking for one. Well, it's the distance the spark jumps at the plug that gives you the info you want. It takes about 17kv to jump a 3/16" gap & 22kv to jump ¼” in the open air, so that's why you need to use a spark plug. Or, a store bought plug checker. Remember, it’s 14psi outside of the engine & about 90psi at a 6:1 compression ratio in the cylinders & compressed air crates electrical resistance, so you really need the 17-22kv to fire the plugs when the engine is running.
Coil problems are difficult to diagnose. For starters, round coils are pretty robust & square coils aren’t, but neither one will hold up to a poorly done 12v conversion that allows too much current to the coil. There are a few ways to see if a coil is bad, but it’s not possible to determine if a coil is good w/o some expensive testing equipment. If you detect a dead short or high resistance in the coil w/ an ohm meter, it’s bad. If it’s cracked, it’s bad. If a sidemount coil w/ battery voltage to the primary will not jump a ¼” gap from the secondary wire to the block, it’s bad. But, here is the hard part: even if you do not detect a short, even if it will produce a spark, even if it’s not cracked, that doesn’t mean the coil will work when it’s hot & under a load. So, it’s a process of elimination. If the tractor starts & runs fine for 30 minutes or an hour then cuts off & refuses to re-start, and you checked for spark at the plugs & it had no spark at all, AND you jumped the resistor AND you jumped the ignition switch, that’s a good sign that you have a bad coil. Let it cool off, restart it & if you have a good spark, odds are it’s a bad coil. But, even then, you might end up w/ a spare coil on the shelf!
But to answer your question......remove the wire on the coil, remove the coil bail & lift the coil off the distributor.
50 Tips
jeff, you just unhook the coil wire from the top of the coil, pop the little wire bail foreward and remove the old coil, put the new one on, making sure that the little wire pigtail hits in the screw head on the points, and push the bail back onto the coil, hook up the coil wire and your done.
Jeff,
After going thru this and 2 coils on my '40 9N ..... be sure you have the resistor in place and working. I can attest that without it a coil will melt.
As you've been told the replacement is pretty straightfoward. You might want to test it first if you have a meter.
Bruce - Thanks for your response. Sounds like you're pretty experienced with these. Might have to fly you in to get it tuned up for me. :) I pulled 2 different plugs off immediately after the tractor shut off and neither showed any spark. After letting the tractor sit for about an hour, I checked again, saw spark on both plugs, put them back in, and the tractor started right up.
Thanks again,
Jeff
Condensors do this.A tight point gap will heat the coil.If you can find an old radio tv man have him check the condenser for capacity and leakage.
as others pointed out.. may be coil.. could be bad switch or even condensor.
find out which.
jumper switch.. swap condensor.. if that don't help.. and te ballast resistor is nice and clean.. then think coil.
cheap stuff first!
soundguy
