9n front wheels
vaganratt
the rims on my tractor are welded to the hubs. Could I drill the bolt
pattern from an automobile rim on the hub and get a tire on this
way, or are there easier and inexpensive solutions? Some input
please. And thanks.
Not sure what you mean by welded. The bolts in the hub are press in. It would help if you could provide a picture.
If someone actually welded the wheels onto the hub I would try to save either the hub or the wheel, or both. Try to cut the weld with an abrasive wheel.
HTH
Posters used to say that the wheels (rims) off an older Volkeswagon will fit the bolt pattern.
Hope this helps ya. John,PA
