(quoted from post at 14:05:22 08/17/23)
Or all the laws of physics have gone out the window.
(quoted from post at 10:29:11 08/17/23)(quoted from post at 14:05:22 08/17/23)
i think it was Dodge that had a commercial that asked "If we break the laws of physics, will we be punished?"
no, because you can't. but good chance you'll be punished if you try.
(quoted from post at 13:50:45 08/17/23) He said the negative cable was smoking, to me that's hot He also said that the post on the starter is loose, sooooooo, I think we are on the right track.
(quoted from post at 05:11:49 08/18/23)
I have to ask how this post went off the rail when its a 5 min job to find the issue.
I am even asking myself should I charge more cuzz it sure looks like this is a complicated issue to tackle. I have came to the conclusion its outside of the rim of most everyone. If I read and did not understand are if I posted and still on the hunt it may be time to back up and ask myself how can I resolve this issue in 5 min.
What questions do I need the answer to, what tools do I need to gather the information.
Don't take my beating to bad its not uncommon for issues like this to make it 6 pages to get back up on the rails. What makes this tractor so different than my Honda Accord, my Ford truck the answer is NUTT'N!.
I can guarantee ya if it were a two hour job to get to the starter off I would know I was not wasting my time.
They all take the same diagnostic approach who would have thunk it.
I think we were trying to help a guy that doesn't understand basic DC circuitry. But we haven't heard from Patriot_knight since Wednesday. For all we know he found the problem and is in the clover now.
(quoted from post at 19:55:33 08/18/23)(quoted from post at 05:11:49 08/18/23)
Big difference between your Honda Accord and Ford Truck. They have a starter with an integrated solenoid. When you turn the key, the solenoid has to hold to keep the starter engaged. You would probably never get to the point where the battery negative gets hot, because the solenoid will disengage.
With those cars, a partial short in the starter itself probably results in maybe one turn of the starter and then the familar chatter of a solenoid engaging/disengaging.
Then they would try a jump start to rule out the battery... which would maybe get one or two starter cranks, or none... and then solenoid chatter.
At which point, most people, with any 12V vehicle made after...oh...1970...or even before... would say "it's the starter" (which includes the solenoid and the starter with the partial short)...they would replace the whole thing and be done with it. For many of these vehicles the bare solenoid either isn't available, or it's almost the same price as a reman starter. So you just replace the whole shebang. (And, in those cases, there isn't a lot of difference in the price for you to economically collect a diagnostic fee for determining whether the short is in the starter or solenoid.)
Not a big difference to you, because you know the difference between a starter, a solenoid, a starter with a solenoid, a mechanical switch, and a starter with mechanical switch. You also have inherent knowledge that the old N's were 6V systems with low ohm starters...and they will behave differently with a 12V battery than a new car with a starter that won't even engage with a weak 12V battery.
Should you charge more for that wisdom? Your choice.
Is that wisdom easy to get across to a person whose only frame of reference is modern thinking where people call switches "solenoids" and call starters with solenoids "starters"... via written text in a forum like this? With confounding opinions (such as my own)? No.
The one question that I ask myself is...if I trust people that have already jumped in on a thread, such as yourself, should I just read and refrain from commenting? Probably should. Because, I do trust that most commenters here would find this problem in about five minutes if they were on the ground with the machine.
This post was edited by lastcowboy32 on 08/18/2023 at 06:58 am.
(quoted from post at 23:05:50 08/18/23)
My wife calls me "Green Eyes" for that Irish twinkle... but yeah...
I've messed with my N and read enough posts here to know that there are, like I said, 2, 4, 8, 16, 32... possibilities of what you have, depending on what was done during their history, based on how many things were tampered with/retrofit.
But, in the end...it's just an ignition and usually it's one of the few main configurations.
