All.
Had some issues with the 9n which caused me to just replace the Carb, Governor, Plugs, Cap, and Coil. (Yes, original problem which was lack of power, then stopped running, was the Coil.)
However, now I cannot get her to run very well at all.
Here is the current symptom. Using the choke to start, it runs up to full rpm and will not idle down. Adjusting the governor, we can get it to come down, but it seems to be either full guns or nothing at all.
Couple of other things. The throttle assembly never had a return spring on it and I never had a problem with it idling down, however, now it seems I will need a spring to assist with this? When it is running at full throttle and I move the lever down, It basically does nothing.
Also, the carb. I have checked and rechecked the needle setting and also I am two turns out on both needles.
Thoughts on things I should check? Before all of this started, it ran like happy cat.
Thanks all.
Eric.
Thanks all.
Eric.
