9N transmission noise
spewingjason
I just purchased a 9N with a junk motor on Friday, Saturday I yanked the engine and front end off my nice running but otherwise beat up 2N and bolted it the back half of the 9. It went real smooth, I couldn't believe how fast it went. I had it driving in about 8 hours. Now for the bad news. The transmission makes some horrible howling noises, most noticeably in high range, but it is there in low too. The 2N does not have a Sherman. I am contemplating swapping out the innards from the 2N and putting them in the 9N. What parts will I need to make it all work? I want to use the 9N tranny case, as it has the hole for the sherman shifter, and the gears out of the 2N. I have not torn the transmissions apart yet or this would all be evident, just trying to get my ducks in a row. Is the howling indicative of bearing failure?
All of my 9N's are noisier than my 2N. Square cut
gears are inherently noisy. The 2N has a helical
input gear. But you could have a bad bearing.
I have a 1940 9n with a homemade tuned exhaust, it is LOUD, I can't hear it over the howlin transmission, as the others said might be nothing, let someone hear it that knows what they are listening too.
My 40 9N whines pretty good even with all new bearings. As others have posted, the 9N's were noisier with their straight cut gears.
My take..
Bad bearings growl,,, replacement is the only option...
Gears wine,,, in some applications you have to go into it to resolve the issue,,, is some cases like yours its the nature of the beast... your call
