9nhydralic pump removal
C.bailey
How on earth is the hyd. pump fastened to the lower cover? There are no outer bolts from the cover in, and no apparent ones on the inside of the tractor midsection from the pump to the cover. If this is a one piece deal then how would the whole assembely be removed? Any advice would be greatly appreciated!!!!!!!
Drain the oil, pull out the PTO shaft, it goes through the pump, then just unbolt the cover. I would put a floor jack under it before I removed the last couple bolts. It should then come out as you lower the jack.
