A John Deere Year and trans
Iowegian
I recently bought an A with s/n557681 the chart I checked said it is a 1945 Slant Dash but it has a 2 stick 4 speed trans one stick is Labeled R and 1-2 3-4 the other has 1-3 2-4 it also has the angle iron frame the serial number is very easy to read and have checked it several times any ideas will be great!
John Deere came with a six speed transmission starting in 1941. With a four speed I would guess it is a 1939 or 1940.
Sumpin's screwy here, one stick, the centered one, should read R in the lower left position, 1-3 in the lower right position, 2-4 in the upper right position and 5-6 in the upper(highest) left position. All this info should be obvious in raised images on the quadrant. Then the other stick(overdrive lever) should have a low position marked by a "L" on the cast cover below the lever to the right extreme and a high position marked by a "H" on the cast cover with the lever in the extreme left position. Now this applies to a 6 speed version. The 4 speed version has the same shift positions except there is no quadrant, the center stick positions are marked by raised letters on the cover casting and there is no 5-6 position at all.
G model tractors had the 1-2, 3-4,(rather than 1-3,2-4) and 5-6 gear setups and the side lever was identified as the "underdrive" lever because the gear arrangement in the G's transmission is different than A's as far as the function and application of the side lever. As an example, low or "1" gear in a A is a direct drive gear and second or "2" is an overdrive gear, whereas in a G, low "1" gear is an underdrive gear and second "2" is a direct drive gear. Now, to further confuse you, the gears operated by the side lever are not used in direct drive on either model tractor, but the difference is direct drive in an A is the low "L" position and in the G direct drive is the high "H" position. Now the "Icing on the cake" is that the gear ratios are such that the tractor speeds are not the same as far as center shift lever position in every speed. Second "2" position in an A will get third "3" gear in a G....and second "2" position in a G will get third "3" gear in an A. Okay...now I'm confused too.
Take a look at the photo below of "EASY" our 46A.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/Easy/?action=view&current=IMG_1316.jpg" target="_blank">
IMG_1316.jpg" width="520" height="420" border="0" alt="Photobucket
</a>
The High-Low lever is on the right of the gearshift.
The gearshift lever pattern is:
Reverse on the bottom left.
1-3 on the lower right.
2-4 on the middle right.
5-6 on the top left.
Hope this helps.
I should have mentioned that there is no quadrant and the numbers and lettes are as you describe for the four speed with this being said if it is in the early 40s whats with the serial number being 557681 although it could have been switched (serial number) why would someone bother Seems like every time I start something like this I run in to weird things.
