I have an original condition 1948 F Cub that I am restoring. The tractor is in excellent condition both mechanically and cosmetically, with the exception of a few nicks and faded paint. I am planning on having it painted soon, and want to do everything I can to achieve perfection prior to the paintbooth. Here is a little rundown on what I have done:
degreased tractor
changed oil/filter
changed trans and steering box lube
repaired bent clutch insp plate
installed new implement mounting bolts
replaced all hoses and tower clamps
flushed and refilled cooling system
cleaned breather and intake caps
cleaned oil cup
Things left to be done:
change final drive oil and gaskets
r&r front tires
clean, inspect and grease wheel bearings
replace 2 dented light rings
r & r wiring harness
replace grommets (before or after painting??)
check front wheel wobble
replace seat with original type
replace grille and side wings
What other things should I be looking for? I do not want to be messing around fixing things after the paint job. The carb leaks when the gas is left on. Should I rebuild it?? It appears that nothing else is leaking, so should I skip replacing various seals and gaskets??
Any and all tips would be appreciated.
degreased tractor
changed oil/filter
cleaned oil cup
r&r front tires
