1964 Massey model 65
AD4.203 Perkins Diesel
UNDM 704769
I put my injection pump back on the tractor today. I'm having a hard time getting the injection pump to prime; Dieseltech says he's certain I've still got air in it. That's good enough for me. I'll keep plugging at it. He said some are easy to prime, some are not easy. It's the way of things I reckon.
Aligning the the pump drive slot with the gear dowel is not too bad, you may have to slide it in and out a few times to rotate the gear adapter until it finally goes into place. You can then reach into the gear end and feel the gap between the gear and adapter to make sure it seated correctly.
That backside pump top adapter nut is a cast iron bi%&*! to get to and it takes some creative ratchet extension configurations to get to it, no mind the patience to tighten. A real pain, that one.
I found I had a leak on the secondary filter when hooking up the lines. This was the rear line that comes out of the filter into the inj pump transfer vanes, the rear of the pump. Could not get it to stop and it looked and felt like the fitting was cocked or otherwise worn out, so I ordered another from Ebay. It was probably drawing air through that fitting.
Also, the fuel lift pump felt like it would stick no matter where I rolled it to I couldn't get full stroke on the pump. Would stroke maybe 1/4" anywhere I rolled it to. Again I ordered parts, another fuel lift pump. The old looks to be original so its 55 years old?
I'm into it now for a secondary filter housing, fuel lift pump, 2 new fuel filters (these only have 35 hours) and the pump reseal.
And the stinking dog ate my injection pump gasket so I had to make another. Its a dog doing dog things.
So parts wise, its turned into a greater undertaking than it should have been, but hey, its an old tractor. I love my tractor.
I spun it with the starter and ran down the battery a little, so I'm taking the Honda generator back tomorrow to charge it back up. It charges at about 8 amps so I won't need to run it too awful long.
I'll update again when I get it running. Getting all the air out has to be the hardest thing.
UNDM 704769
