Sibaird_mf40
I have a MF40 backhoe with the Perkins motor. I started it up after about 12 years and it ran for about 20 seconds. I believe I had the fuel shut off and so now it’s full of air. I’ve replaced and bled the fuel filter ,and the 2 bleeders on the injection pump. The manual hand pump works fine, I’m able to pump fuel to these areas and push the air out. I cracked the top bolt on the injectors and only some fuel came out, there has been some air bubbles also. Still the tractor won’t start.
Should I be bleeding the injectors at the fuel line that connects to the injector? I’m assuming the top line that connects all 3 injector is a return line or something? I read that I should crack them open then crank it to force the air out?
It ran perfect for 20 seconds like I said and it acts like it wants to start on ether, so I assume it has spark. Oil PSI goes up to 40-60 range while cranking. There is also a small amount of white smoke coming out of the pipe.
I know very little about diesels so please fill me in.
