Is it normal for a AC 149 gas engine to run above the thermostat temp? I just did an in frame on an ole D15 that did not have a thermo in it previously(former owner no idea why) It warms up to 170 and stays there until I put a load on it then goes up to just shy of 200. I did try richening up my main jet but if it made any difference it was less than 5 degrees. I am getting good air flow through the radiator, I do not know the condition of Water Pump or the inside of rad beyond not leaking.
I do know before the resleeve without the thermo the temp never moved until I got to heavy load then it would get up to about 170 and hang out there.
