AC-DC welder
keh
Lookng at a used small Lincoln AC-DC welder. Somebody want to fill me in on DC advantages? It's been a while since I read up on DC.
KEH
Keh. Right off I"m far from an expert welder although my experience with D.C welding is ,I could weld Horizontal (and vertical) with no problem of spotty weld overs, and slag deposits. I sold my straight A.C.welder and bought a A.C/D.C. Built a couple of Equiptment trailers . First welder I ever owned was a "SHUNT TYPE Marquett(sp) And I wished I would have kept it.
With that one, I was so confident I could weld clouds lol. D.C. For my son . Good choice. JMHO LOU
(quoted from post at 23:44:40 07/26/13) Keh. Right off I"m far from an expert welder although my experience with D.C welding is ,I could weld Horizontal (and vertical) with no problem of spotty weld overs, and slag deposits. I sold my straight A.C.welder and bought a A.C/D.C. Built a couple of Equiptment trailers . First welder I ever owned was a "SHUNT TYPE Marquett(sp) And I wished I would have kept it.
What is a shunt type welder?
Dc runs smoother and works better for vertical and over head. Most rods will run better on dc. You can also run 7018 rod which is my rod of choice.
Like a rotary dimmer switch. The more amps required the shunt closes to keep power at the setting without burning the welder up. Best way I know how to explain it. You can google shunt type welders. LOU
PS link below is as close as a description as I can find.
poke here
Going to DC from AC is like night and day!!!! Every portable welder on the back of a welding truck is DC. If you ever needed to hire a welder and tried to save some money by letting him use the AC welder on site, he'd probably cuss out loud several times and hang up on you!
A shunt type welder is one that changes amperage by moving a core through a pair of secondary windings in the transformer. Any welder that has a crank or a large lever is probably a shunt type welder. They're often described as infinitely adjustable. The most common alternative is a welder that gets different fixed amperages from individual wires called taps which are connected to different locations on the windings of the transformer.
A tapped welder is one which changes amperages by clicking a lever on a dial with very little force, like a Lincoln buzz box, or has a series of outlets on the face of the welder marked with different amperage settings, and you plug your electrode holder cable into the hole with the amperage you want, like some old Forneys (and at least one old Lincoln model)is the most common alternative type of transformer welder. It's not infinitely adjustable because you can't (easily) go to any setting except those fixed settings. You can't dial in your amperage setting with perfect accuracy, but tapped welders don't go out of adjustment like shunt type welders.
Stan
keh...If the consideration is a small Lincoln AC/DC 225/125 buzz box which has an open circuit voltage less than 80V, electrodes such as E7018 with iron powder in the covering will be hard starting. E7018 can be used, but welding will be frustrating because the electrode easily sticks fast to the work piece due to the low OCV. Operating characteristics will not be those of an Idealarc 250, an inverter, or the typical Pipeliner motor/generator. However, DC will produce a smoother arc with less spatter than AC and welds just fine with 6011 or 6013.
