acb hydraullics
does the hydraullic system on a b ac use 90w or the newer type fluid, also does it have a fluid inlet and outlet to work hyd cyclinder,where are they located.thanks larry
You can use either the 90W oil or the newer hy-tran type oil. It does need to be a tranny/hyd type fluid because it also is used to lube the tranny. Also its set up to work 1 way cylinders not the double acting type. There's 2 or 3 ports on the pump for cylinders
Hobby farm
