Adding coulters to Dearborn 10-156?
Coyotefred
Hello!
I have a Dearborn 10-156 plow that I bought without coulters (see pic). I"d like to add some. I"m not doing a restoration, so any coulter setup will do. But someone told me that adding coulters to this plow will be difficult since the coulter stem is 1 1/8 which is difficult to find, rather than the more common 1 3/8 or 1 1/2".
Is the problem that the two holes where you"d mount the stem with some kind of U-bolt (?) are too close together to take the more common 1 1/2 or 1 3/8 stems from other companies or models?
"Any thoughts/advice appreciated.
Coyotefred
The main reason there is none on it is coulters don't work very well. Takes a lot of down pressure to hold them in the ground. I used to think I needed them and put them on three plows I used to use. Before the end of the day I took them off and threw them in the iron pile, never used any of them again.
So the plow worked OK for you without the coulters? I just bought the plow cheap from a neighbor from his scrap pile and haven't had a chance to use it yet. Some folks on another forum suggested the coulters were usually important to have. My soil is very fine sandy loam and doesn't stick or bunch up much. But I will be plowing some ground with a fair amount of mowed-down weeds on the surface (but not thick sod).
Coyotefred,If you want your plow to do a decent job of plowing and covering weeds and sod it needs to have coulters on it.Find some and put them on it.Why do you think it had them when it was new?It will also pull easier with them to!
Oh, and that plow has the wrong size shares on it for the size of the moleboards it has.They could be cut off and made to wor right though.
Fred-
You don't need coulters to plow with the Dearborn Plow and as was mentioned, you don't have the correct points, or shares on your plow so that may be why you can't plow or why it does a bad job...TSC carries the 14" points for ya...if you still wsant coulters, I have some originals. I have not seen anything new anywhere.
Tim "PloughNman" Daley(MI)
Coulters are a neuseance when plowing in trashy ground. The will clogg up and make you have to stop and clean them off or the plow will just ride on top of the trash build up.
Don't use them!
Zane
