Btzj02
I just completed major work on the rear end of my 1951 8N and seeing that I live in Minnesota and the Pole Barn is not heated I wanted to add the hydraulic fluid before it got to cold. I will not start the tractor till spring but, like winterizing my motorcycle, I like to have fresh fluids added before a long winters nap.
I have read in many places to remove the lower bolt on the inspection plate cover and add oil till it comes out. So that is what I did. I emptied a partial bucket of oil and started adding from a new 5 gallon bucket. As I was watching for the oil to come out the bolt hole my funnel filled up with oil and I overflowed the transmission case.
I had a pretty good laugh when I realized that the oil is so stiff it does not flow very well. I let the oil drain until the system equalized and then buttoned it up. Good thing I have a lot of saw dust around the shop to soak it up. I did not split the tractor, but every other gasket is new and oil is no longer running out the 3pt lower pins. The Question: will my clutch be impacted by this little caper?
Joe
Joe
