Adding remotes to a Ford 8000
hueyrescue
I have a Ford 8000 with one set of remotes. I'd like to add a second set. I know that this was a factory option so I am thinking it should be straight forward. Do I need another valve or can the existing valve handle two sets? Thanks for your help!
I believe that you need another valve. Once you get it installation is very easy, three bolts out, you will need three longer bolts, cap off, probably some new O-rings additional valve and cap back on. Between installing the valve and the lever linkage you will probably save time if you remove the wheel.
