Addl Hydraulic Outlets
I purchased a accumulator grappler set to move square bales but found my JD 5200 with a joy stick needs an additional hyraulic outlet.
Have any of you added an additional outlet by piping in a 12v splitter valve? If so, what brand model splitter did you use?
Any problems doing it that way? JD dealer want to sell me a Fasse valve at about $600 or add an additional outlet with factory set up for about $1300.
Thanks guys !
Does it have to be so complicated or as expensive as an electric valve?
I needed a stick for my frontloader when I added it. Plumbed a block into the main pressure line with a return dumped into the resevoir. I can add as many sticks (hydraulic outlets) to that block with just the cost of a joystick (75 bucks). My entire setup cost me about 150 bucks including a couple new hoses.
Dave
If the 5200 is open centered. The advice given isn't going to work.
The valves are added in series rather than in parallel for open center.
Third SCV kit is Part# LV100117 cost is $571.00 plus freight. It is not technically hard to do but you will need to remove the right rear tire and fender. The main system is an open center system.
