adjusting bf steering?
I am guessing you are asking about the steering gearbox under the radiator and I don't think there is any adjustment if the gears are worn. But its getting to be several years since I worked on one.
You could try asking over on the Avery Tru-Draft website, it was originally an Avery design.
there should be a way to titen it up ,mm or avery would not send it out like that , look closely for a bolt or nut somewhere with a slotted screwdriver tip ,, it mite be filled with mud crud ,, pretty triky on my 511 b case ,,,it sector adjustment at 1st glance looks like a fastenin bolt ,, on the case it is on left side front on lower part of pedestal
