Adjusting clutch on CC update.
Farmallb
Ive got the clutch tightened up real tight,. It holds back and snaps open. UNTIL you drive it, than it continually falls forward. It seems to hold till I run it slow, it holds better, actually real good, but when I open it up it continually falls forward. I readjusted the clutch pulley stop pad bracket, and used it tonight on the brush hog, but had to constantly hold the clutch back. Its got great pulling power. It was evening and the grass was damp and rank, and that would pull her down on a 7ft bush hog brand brush hog, but she slogged through it all and we finished fine, so I know the clutch pads arent slipping. I got the I & T repair manual.but it dosent say a thing about what to do if the clutch handle wont hold back in gear.
Does it SNAP when you pull it back? Should require about 50 lbs pull to make it snap back. Maybe you have it too tight.
Yes, it snaps good when you push the clutch in. Whether it would snap or not when it goes in on itas own I cant tell ya, but otherwise, yes it snaps good
