I bought a Rogers, commercial grade, skid mounted, air compressor, at a consignment auction. It was originally hard wired, but I put a 240 pigtail, on it to try it out at home. It has a Quincy model 325 18 2 stage compressor on it, and is shutting off at 145 lbs, tank pressure. None of my smaller compressors, go that high on tank pressure, and I am wondering about adjusting the pressure switch, down to 120 lbs, for safety? Is this needed? I also found an air leak on the unloader valve tower, and have ordered a new diaphragm, for it. I hope that seals the valve. Do you recon, that excessive air pressure, might have caused the unloader valve to leak?, I still hear the unloader valve unloading, when the unit shuts down, so I guess it is still working.
