Just bought a used 60 gal air compressor 5 hp motor, in reasonable shape. there is some rust in the water drained from the tank. I plan to plumb it in my shop and am cleaning it up now. I know I will need to drain it after each use, but does it make sense to try to rust proof the inside of the tank before setting it up? Over the years, the thing that killed my compressors has been tank rust out and I want to avoid it. It occurs to me that I could pressure wash it out via a 1 1/2 bung on the side, dry with warm air, treat with POR etching primer and spray a finish coat of POR rust preventer in, again letting it dry for a logn time and then plumbing it in. So, questions: is it worth doing at all? any downside other than cost and time to this plan? any better suggestions?
