The "BEST"?? That answer might be argumentative. What's your intended use?
I have 3. One is Central Pneumatic and is my powerhouse. It runs slower than the other two, but has much more hitting power. It is all-metal, and now about 15 years old.
I also have a Campbell Hausfeld with plastic casing. It hits lighter, but has many more hits per minute. The plastic makes it much easier to use in colder temps.
...Offhand, I can't even remember what brand the 3rd is. I bought it and tried it out, but was sorely disappointed.
Ingersol Rand has some very good (and very spendy!) models.
I guess it depends on what you plan to use it for as to which is better. There are light-duty, medium-duty and heavy-duty. If you'll be chipping out concrete or something similar, I would recommend an electric hammer/breaker like this one. This thing ROCKS!!
https://www.amazon.com/gp/product/B00IO3Z5MS/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
If you're looking for something that can make a hole in concrete floor (for example, to put in a sump basin), you could simply use a hammer drill and drill lots of holes in a circle, then break out the center.
I have never used an air hammer for cutting mufflers & such. Tried cutting some metal one time, but had other tools that worked better.
I think you are just asking about chisels, correct? If so, I have MAC chisels for mine, Snap On are good, too. They are spendy, but are life time warranty. As far as the hammer, I have a long barrel MAC. I want to get the job done, not make noise and ring my ears.
It all depends what you want it for. I have 3 of them; Light, medium, and heavy, all the cheapest I could find (Ebay, etc.). The first two I usually use with a regulator for riveting. The heavy one I use for things like splitting tie rod ends or cutting off rivets on ball joints, etc. It doesn't matter what brand you buy. Just look and compare the specs; the bigger the bore and stroke combination the more power they have, just like an engine.
Chicago Pneumatic CP717 Super Duty Air Hammer is the best the price has came way down on'em, next Snap-on PH3050B... I use the Snap-on with snap-on bits because it will snap the bits off and they warranty them... I had a snap-on PH2050 it stayed broke about as much as I used it it broke so much I kept the parts in stock the parts were cheap tho... I got $100 on trade in on the PH3050B its been a good'N I am happy with it...
The CP717 use to run in the 5/600 dollar range...
I have a Husky sold at Home Depot I got mine at the dump after the Snap 0n guy dumped a load of trade ins off. It drove the studs out of the hat rims on my 46 2n with no trouble.
We used Ingersoll Rand in the tire shop. Far cheaper than Snap On or Blue Point. Keep them oiled and they will last you a lifetime. My chisels came from NAPA. Except for the actual air hammer--hammer. I had to get that from Harbor Freight. We used it to loosen up siezed on brake drums.
